I've replaced three GU10 fittings like the one below without issue. It's been as simple as grabbing one or two of the lugs and twisting anticlockwise. The inside white ring then twists about a centimetre and then falls out from the middle ring. The light blub with then fall down slightly, and one can unscrew it from the connector and then replace it by reversing the process.
The one below pictured however won't budge. At all. I've even tried grabbing a flathead screwdriver and pushing with considerable force against one of three lugs, but nothing is moving. Without removing the inner ring I can't remove the blub to replace it.
Does anyone have any idea how to deal with this?
