Sorry it's a bit wordy, but I've provided quite a bit of info.
My system comprises of:
A Baxi Solo 2 80PF boiler with the thermostat set on 5 out of the possible 6
settings
14 radiators (3 small, 2 medium and 9 large) All bar one with TRVs
Danfoss SET 5 timeswitch
Grundfos Super Electric pump set on 3 out of the three speed settings
(numbers on it are: TF110, IP42, UPS 15-60 if that helps)
W-Pan or Y-Plan (don't know how you can tell which one it is) valve fitted about 6 inches from the pump. "Honeywell" seems to be the only marking on the aluminium coloured case.
Danfoss hot water tank thermostat set on 70 Degrees
Honeywell Room thermostat in the hallway
History:
Moved into the house in October last year. Before that, the house was empty for a year with the heating turned off and drained. Some of the TRVs had stuck and could not be freed up using pliers etc so I had a plumber replace all the TRVs and service the boiler. He checked out the system and everything seemed OK.
I regulary bleed the radiators but after about a week or so of replacing the valves I've never managed to draw off any air from any of the radiators. All radiators come on fine and TRVs seem to be working well. Furthermore, I cannot see any leaks in the system and all physically looks well.
The heating works fine in the morning as it is only on for about three hours. However, After it's been on in the evening for several hours, every now and again I hear a whooshing/ girgling/ banging noise coming from one of the pipes in the airing cupboard that leads up to the attic. This varies in volume up to the point when it seems as if every pipe in the airing cupboard is going to rip itself off the wall. Then everything settles back down again for say 20 minutes before the whole thins kicks off again.
I've taken a closer look and I have five pipes going from the airing cupboard up to the attic. One is the cold feed, two are warm to the touch and two are absolutely scalding hot. The two pies that are scalding hot come from a single pipe from downstairs. This single pipe also feeds into the pump. It's these scalding hot pipes which are making these fearsome noises.
Any ideas? I've tried running to the kitchen to see what noises the boiler makes and to be honest I reckon it must start there as I always catch the end of some banging before the noise propogates up the pipes into the airing cupboard and finally the attic. Is the boiler thermostat too high? Is it kettling (I think the term is called). Could there be a problem with the pump? What about the valve?
Thanks in advance.
settings
History:
Thanks in advance.
