Our basin has quite an extreme case of gurgling in the u-bend, but a second or so after that has stopped there is a gurgling/'air passing through water' noise in the waste pipe under the floor somewhere. The floor is tiled so I can't identify exactly where it's coming from, and it's more of a 'bloop, blabba-bloop' sound, as opposed to the 'gulaggle-laggle' sound from the basin. (if it helps to diagnose, I'm happy to make these noises down the phone for you).
Neither the shower nor bath seem to trigger any similar noises, and there doesn't seem to be any restriction on the basin water going down the waste, it drains as fast as the tap can fill it.
Is this likely to be a simple blockage in the pipe, or could it be something to do with the venting? Have tried soda crystals and hot water, but wondering if it's worth probing a drain unblocking tool down there.
