Hi, I need to install some guttering around my new extension. The problem is one of the corners is 160 degrees. I have only seen guttering corners 90 or 135 degrees.
Guttering is to be roundline 112mm in white.
Is it possible to get 160 degree gutter corners, or have it made specially? If so where is the best place to get it from in the Reading area (or if you know of an Internet based, or mail order based supplier)?
