gutter clips what degree of fall??
2 Jan 2011
Kent
when fitting new guttering and clips how much degree of fall should you be aiming for??how close to the tiles should you fix the first clip,and how much lower should the end clip be,i will then run a stringbetween the 2 clips and fit the rest.pete :)
1. Why not research this on here - there's masses of gutter installation advice?
2. First sort out your outlet(s) and RWP's position(s).
3. How high the first clips are fixed depends on the length and complications (if any) of the run to outlet(s).
