gutter corner supports
23 Aug 2008
Essex
Hi, any idea's about how to stop gutter corners from sagging. When ever you put up gutter corners they just hang there the only part that is not screwed or supported to the fascia board so it sags.
Put a clip either side of the corner, about 100mm away, then it wont sag
Hi chris_o, so simple when someone tells you. CHEERS.
