the garge is now white! and all new facias/windows etc
i have had a thought after talking to someone in the office, i think best idea might be to put some duct tape around the pipe as it keeps coming out of the 90 degree bend joint (before it goes down the side of the property) this should make the fitting tigher (i hope)
i could put a screw in the side of it and im sure that would hold it - duct tape you would never see it as the joint is bigger than the pipe it self - would just make the joint tigher (thats the plan)
