My neighbor has replaced his plastic guttering , his is metric and ours is older imperial ,the joint union is leaking bad on to our property. How can I join the two different size gutterings to stop this.?
If I remember correctly - floplast can fabricate a custom joiner for you. It may be expensive (around £50) - but it's a hell of a lot cheaper than replacing everything.
