Gutters suppose to hold a bit (2 cm) of standing water?
31 Mar 2009
Victoria
I recently had my gutter done, and upon testing (spraying water onto the roof). It seemed at the 2 front corners of the gutter are holding water; about 2 cm of it.
I called the guys who did it, and they said:
- the gutter are suppose to hold some water
- if they make fall too much it would look ugly
- And want me to install a down pipe straight to my garden.
Does it make sense?
most gutters i have seen are empty, you dont want water sitting around it could go stagnent or become a home for the bug you get maleria from
Gutters are not suppose to hold water, I can't believe the guy said that to you. Gradual falls can be applied to a length of guttering that will allow all the water to drain without the fall being very noticable. Although, corners will tend to hold about 2mm of water.
Hi. Most gutters hold a bit of water over time owing to leaves/sediment etc. However if its a bungalow with long runs between outlets it can be difficult to achieve a fall without compromising the aesthetic. As for discharge on to garden, Australia may have differing reg's to that of the UK. Good Luck
Gutters will inherently hold water as it is impractical to get a fall which will dispel all water.
The actual concept is that they fill up to such a point as the water "overflows" down the outlet, not that every drop rolls down to the outlet
The OP's problem seems to be that the two corners are lower than they should be, which is different to the gutter holding water, and so it is a quality issue.
