Hey Guys,
So i wisely decided to do some electrical work after getting home from a long day at work...bad idea.
I was re-attaching a faceplate that had been annoying me for a while, then when i turned the circuit back on (kitchen socket ring) it tripped both the breaker and RCD at the same time. Unscrewing the faceplate all the way shows that i had managed to screw straight through both live conductors giving a short to earth.
I cut off the damaged bit of live and connected them both together again (checking further down on the cable for any issues, but it looks fine) reconnected the socket, turned the ring back on however whilst it doesn't trip there is clearly a bad connection as the fuse board is making a 'buzzing' sound (i don't leave the breaker on for long!) and even just having the phone plugged in the kitchen (i've turned off all other appliances, the fridge is currently connected to the separate downstairs ring main) it beeps every few seconds as if it's being plugged and un-plugged, so clearly there is a bad connection now in place.
I've checked all the connections on the faceplate, i've even taken the faceplate off, soldered the wires together and used a 30a chocblock (so no faceplate connected) however still the problem persists.
My only thought is that it's either -
1) Cable is damaged past the socket where i can see it, however it's in the kitchen and i really don't want to start pulling that apart
2) I've damaged the breaker in the CU (is that very likely?!)
Thanks guys
Thanks guys
