Had a go at plastering with multi-finish on the toilet wall today (approx 4ft square area)
Initial panic set in when I saw it beginning to crack where it was drying out too quickly. Managed to save it by keeping it watered with a spray bottle and troweling across it but it took ages!
I did PVA the walls last week and then again just before starting the skim.
I'm quite pleased with the results - flat and smooth across 99% of it, but then it was only a small area.
Was it because I didn't make the mixture thin enough in the first instance that made it dry out too quickly? I had a smooth consistancy slightly thinner than a cement mix.
Does it need to be alot runnier to prevent this next time? I assume it does as I must have applied another litre of water to it when it was on the wall!!
And what it the best way of meeting ajoining walls/internal corners?
