Hi all.
I have a 7 year old Haier HW-70B12636 washer. It is erroring F7 and won't spin. Resetting by holding down start before turning on isn't clearing error or allowing it to spin.
I already replaced the PCB successfully about 3 months ago which you could see had blown a resistor and was generating FC1 error. This new PCB still looks fine, so I assume it isn't that. I have used the machine about 12 times since no problems.
With much efffort I have now taken out the motor coils. It is an integrated direct drive motor where coils and magnets are attached to the back of the drum (not belts). I have taken off the coils and tested resistance with a multimeter. I get about 40 ohms on each of the three connections and it isn't shorting to ground on any of the three. ChatGPT tells me the resistance should normally be under 15 ohms for these sorts of motors.
Any opinions on that please? I am unsure whether to risk claiming on the lifetime motor warranty if they come out and charge me because they'll say it's been over-filled or it's not the motor.
D
D
