haier tumble dryer error code E2
20 Jul 2010
Northumberland
Hi all my haier tumble dryer is displaying this E2 error code shortly after program is started, to combat this i have just been turining the machine off and on untill garments are dry.
Does anyone out there no how to solve this issue?
Regards
Si Coe
I suspect E2 is a heating problem, but how you fix it is a mystery as service information & parts are hard to come by.
Low quality unreliable Chinese junk. Best advice....throw it in a skip & buy a tumble dryer.
Thanks for the reply zipper heating was not an issue really, i stripped it all down wiped conectors with sandpaper? motor,belt and heating element all in good nic, board looks fine, for some starnge reason i put the door on the opposite side, machine has done a towel load and a genral load with out fail :p
Cant put finger on what i corrected but will see how long it lasts
May help others with same problem
Si Coe
Well you got it working & that's the main thing.
By heating problem I was thinking more in the direction of a faulty sensor rather than a defective element. It may also have been a bad contact & you already cured it. The problem with cheap Chinese appliances (badge or no-badge) is that once they are out of guarantee you're pretty much stuck. Service information and spares are difficult to track down. In eagerness to part unwitting consumers from their hard earned cash some manufacturers are flooding the market with sub-standard products which end up prematurely on the scrapheap.
But the consumer must also share some degree of responsibility in this. Buy cheap....buy twice.
