hairline cracks
26 Apr 2014
Manchester
I'm having trouble with one wall that's traditional plastered, I have given it a mist coat of white contract emulsion 50/50 but I'm seeing what looks like hairline cracks that run diagonal in various spots
If I run my finger over them I can feel the paint where it's raised, the paint doesn't sink, i have tried giving the lines a light sanding but if I paint over them again the lines reappear.
Whats the best solution to deal with this?
I have found that the best way to keep them at bay is to rake the crack out so that you make it slightly wider and deeper ( use an old screwdriver or similar) , then fill with easyfill or a good fine filler.
The filler may shrink back a little and you may have to repeat the process but once sanded and painted, it will be like it wasn't there at all.
Mike
Try using kitchen and bathroom paint on the hairline cracks as it is good at filling hairline cracks and is very flexible then paint over.
