Hello everyone!
I have a problem with my lights. This is my story....
my girlfriend yesterday attempted to turn on the bathroom lights, and suddenly half the flat went dark.
The rooms affected were: bathroom (4 recessed spot lights and 1 small fan extractor), kitchen (5 recessed spot lights), and lounge (2 wall lights and 1 ceiling lamp). So, I went to the consumer unit (or fuse box) thinking that something triped. However, all fuses were "UP".
In my consumer unit I have WYLEX MCBs and also what appears to be 2 main switches. I think one switch controls the upper row of fuses and the the other the lower one. From the labels and from testing what is controlling what, I think the MCB controlling the circuit is the lower one (WYLEX B16), because whether it is on or off nothing seems to be affected. unfortunately all the other MCBs in the box are different amps so I cannot try to put another in (I mean to swap them).
The lights used to work fine, without any previous problems, so I dont think it was an overload. Also the fact that all fuses were on and none triped, means there is a short circuit somewhere???. I made a visual inspection of the bathroom spotlights but I did not see anything abnormal (mind you I am not sure whether I would recognize a blown spotlight - I ve never seen one!).
Any ideas?? If it is the MCB that I need to replace, I noticed that they sell them with the corresponding base (B16 is blue). Will I have to replace the base in the consumer unit or can I just use the existing one? Is there anything I should look for in order to diagnose the problem? (i.e. anything on the MCB that may indicate that it needs replacing).
Any help much appreciated! Thank you!
Solomon
Solomon
