It is usual to have skirting where a half-tiled wall meets laminate flooring?
In one of the 2 rooms only 2 walls will be half tiled with the other two having skirting.
I've got some wooden trim, should that fix to the tiles to allow the laminate flooring to expand?
Should the bottom row of tiles be fixed a bit up from the floor to allow the laminate to go underneath?
Should I do the floor before the tiles?
