Tiling novice, looking for bit of advice on the best way to get this half tiled look.
The only areas to be tiled in the bathroom will be the bath and the sink splash back. The rest will be plastered.
I'm not a fan of the boarder tiles in this picture so I wanted to know is there some kind of tile trim that could be used to edge finish the last rows off.
The other issue I have is that the bottom 7'' of the wall that runs around the bath isn't nearly as flat as the rest. Could patching plaster be used to make it good?
Tiles will start at the two pipes on the left and continue to the edge of the window.
