Following the integration of our lobby/utilty area into our kitchen (which required raising the floor), I now have a level floor of which half is wooden floorboards. These butt up against the new raised concrete floor and the two surfaces are level. However I want to lay vinyl throughout and whilst I can lay 4mm plywood on the wooden floor, I want to continue across the concrete so I still have a smooth surface.
I appreciate I will need to lay a thin damp membrane on the concrete, but how should I fix the plywood to the concrete? I thought about some form of glue, or even masonry pins?!
New kitchen arrives Tuesday so any help will be appreciated!!
