At the moment I have one light downstairs and two lights upstairs. I have a single light switch downstairs
And a two way gang switch upstairs. I can operate all lights from upstairs but can’t turn the upstairs
Lights on from downstairs.
Wiring is as follows:- Two cable downstairs Cable 1 and 2 ,Two cable upstairs cable 2 and 4
Downstairs I have cable 1 black connected to L2 and red connected to L1. Cable 2 Black is connected to C red
Not connected
Upstairs
The switch has 2 banks of connections Top L1 unconnected L2 black from cable 3 Common is strapped to Common form bottom bank.
Bottom Common also has a red wire from cable 3 bottom L1 red from cable 4 and bottom L2 black from cable 4.
Cable 4 controls the downstairs lights from the upstairs switch.
As I’m decorating at the moment I thought it would be good to be able to operate the upstairs light from downstairs.
An electrician mate of mine looked at the wiring and said yeah no problem you won’t need to run a new cable.
Trying to pin him down is another matter.
Is it possible still to have the same switch layout so that the downstairs single switch will operate both upstairs and downstairs and still have a two way switch upstairs and just change the linking strap?
Not connected
Upstairs
