Hi all
I have just bought a house which has a problem with the landing light. The downstairs double switch has been changed but not wired up on one side. I will explain the best I can so bear with me. The wiring is the old system. The issue is with the upstairs light as the hall works perfectly
The switch upstairs is a single switch and is wired as follows
C - switched live which goes to switch downstairs
L1 - 2 x Black (Neutrals) which appear to goto light neutrals
L2 - Red live 240v
The downstairs switch is not wired but I have
Switched live from upstairs light
Black wire with a red sleeve which appears to go to the light live side
Red 240 volt live
The earths are attached to the pattresses.
If anybody could offer any help it would be greatly appreciated.
Gaz
L2 - Red live 240v
Red 240 volt live
Gaz
