We have just had a disasterous building company install a bathroom for us. In the end we had to ask them to leave. I am gradually looking at their work to see what needs to be redone, and what can stay.
Today one of the ceiling halogens stopped working in the bathroom. We replaced the bulb, but it still doesnt work. On investigation I found that the live wire insulation close to the unit into which you plug the bulb has melted.
I have looked at the wiring above, and it appears that each light has its own transformer.
Is it possible that the wire has melted because the voltage being supplied to the light is too high? And if so how do I check? Or is there some other explanation?
The light socket appears to have 25v 45A written on it. 6 lights. On one dimmer outside room.
The transformer says:
Model T02 Electronic Transformer for LV - Halogen Lamps. Dimmable. PRI: 240V - 50Hz
60VA. COS0=0.99 SEC:11.6v - eff Max: 4.9A TA=50C TX 85C
Hope someone can advise!
