I have a Halstead ACE Combi boiler (I know people hate these) installed. After running the bath or taking a long shower steam can be seen and heard escaping from the back left hand side (if you look at the boiler from the front) of the boiler. The result of this is I get condensation on the wall behind. I am concerned about this for two reasons, the first is that I don't think it should happen if the boiler is working correctly, the second is that i'm having the room replastered and the condensation ss going to make a mess of the newly plastered walls in the kitchen.
I have the boiler under maintenance cover with British Gas but every time I talk to an engineer about this they say that this is normal and the boiler is just releasing pressure. I have a copper pipe that is installed through the external wall to the outside which I understood was for pressure relief.....is the engineer correct or is there something wrong with the boiler ?
The boiler does not require topping up and the hot water delivery does not seem to be affected by this.
Any advice appreciated.
