my halstead ace combi boiler does not work on hot water only setting .it works fine with heating and hot water setting.when u turn the hot water tap on its cold water it does not fire up. i have had a look and the valve that turns the electric switch to light the boiler etc does not come out it does a little but not enought to reach the microswitch. i have modifyed the switch to turn on by bending it inside the hot water comes on fires it up but the water is only slightly warm. maybe its the pressure valve or is it maybe the unit its attached to any help would be great. its 4 years old light use
