Hi All
I've started having issues with my Halstead Ace High and I was hoping that someone with greater boiler knowledge than I might be able to help me pinpoint the fault.
After running DHW for approx 5 mins the burner cuts-out, the water runs cold and then the burner re-lights within 10s - 30s of cutting out. Whilst this happens the 'Hot Water' LED on the control panel remains on. This cycle then repeats, but with the burner cutting out at intervals ranging between 1 and 3 minutes.
Further Info:
1. The resistance of each of the DHW and CH thermistors is just over 10Kohms at room temperature.
2. The diverter valve's diaphragm was replaced ~6 months ago as it had split - as far as I am aware the new part is still fine.
3. The problem seems to be worse in windy weather - a gust of wind often makes the burner cut out.
4. CH appears to be fine, although suffering from the same issue as DHW in windy weather.
5. Water pressure is high.
6. Water is soft.
7. Boiler is about 6 years old and hasn't been serviced for at least 2 years.
Any pointers would be greatly appreciated.
Chris
Further Info:
6. Water is soft.
Chris
