Hi
I am currently having problems with my Halstead Ace High Combi boiler after 5 yrs of faultless service. It started with intermittent DHW, which was cured by the replacement of the DHW diaphragm. Now the DHW kicks in but after a short while the burner light goes off and the water temperature drops for a short time. Then the burner re-ignites and the temperature rises. This is continued throughout the draw.
As stated, I have replaced the DHW Flow Switch diaphragm, the plungers rise when the tap is opened and the switches actuate every time. The Boiler always fires and the the fluctuating temperature problem.
After reading other threads on this site I have removed, checked and cleaned the DHW Heat exchanger and the Water Flow Regulator, but to no avail.
Can anyone suggest what could be at fault or what I could try next ?
Thanks.
Thanks.
