I have a 10 year old Halstead boiler, which has actually only been used in the last few weeks. It appeared to run ok for about 1 week, until I discovered the Ignition Lockout neon was illuminated. I reset as described in the users manual and the boiler relit, although there was some noise from the pump (sounded like a lot of air in the pump) and within a few minutes the boiler had shut down again with Ignition Lockout neon lit again. Having tried to reset again, when I start the boiler, the pump starts (no noise now) after a few seconds the fan starts in the boiler and I can hear the igniter sparking. No gas comes through to the burner and after a few moments the boiler shuts down again, with I. L. neon lit again. I have followed through the Fault Diagnosis chart supplied and have 240 volts at the various pins, the only puzzle is the pink dc voltage line, terminal 1, which is supposed to read 10Volts DC if OK and 1 V DC if electronics are faulty, reads around 50 Volts?
Anyone had similar problems, or useful advice, I would like to hear from you asap, as its getting cold out here in somerset.
Any help would be more than welcome.
Cheers M
Cheers M
