- Joined
- 17 Sep 2004
- Messages
- 7
- Reaction score
- 0
- Country
I have re-posted this because what I said last time was inaccurate.
My dad has a three and a half year old gas boiler (Halstead Best db 50 a.k.a. Wickes LW50ci). He has spent a lot of money on engineer call-outs but has yet to overcome the problem.
Today we did some simple testing.
We started the boiler and then deliberately shut the gas off. The flame in the gas chamber went out immediately. About six or seven seconds later, the Ignition Lockout Device (ILD) come on. This is as expected. We then turned the gas back on.
From cold, the boiler worked for an hour or two. Whilst out the room, the boiler switched off and the ILD light came on.
We put the central heating thermostat (CH) to max, reset the ILD, and sat and watched.
After a few minutes we heard what sounds like a switch or relay clicking off and the flame went out. This was despite the room temperature had not reached the level that the thermostat was set at. After a couple of seconds the gas re-ignited, however as soon as the flame detector started to glow, the system tripped as the ILD light came on.
This now happens repeatedly. The gas will cut out after about a couple of minutes and the ILD will ‘trip’ a few seconds later.
Could anyone possibly suggest what might be the fault, or where we might start looking?
We have tried using a ‘spare’ ILD and it does the same thing. However, the ‘spare’ ILD’s history is unknown. The ILD is a Honeywell S4565CF.
Many thanks in advance.
