Hi guys,
I have a a Halstead Finest Gold Combi boiler - around 10 years old. It's mounted in the loft on an outside wall.
Once in a blue moon (perhaps once or twice a year) it has been a bit sluggish when responding to demand for hot water, usually in cold weather. Usually after closing and re opening a HW tap all is fine. Never stopped working and I've never noticed any CH issues. Otherwise it's been reliable and working fine for the 5 or so years I've been with it.
It's now giving a fault. Over the last few days it's been regularly failing to respond to demand for hot water and now it also seems to stop the CH also when this is happening. It tries to start up when it sees demand for either CH or DHW, but then stops 1-2 seconds later. It wasn't bringing up the red fault light/safety interlock - was as if it started up and then decided it didn't need to be operating? Starts up a few seconds later and shuts down after 1-2 seconds again, carries on like this for several minutes.
I had a quick look a couple of days ago - the system pressure had dropped to 0.5 bar so I topped it up to 1-1.5 bar and it was all working okay - or so I thought.
Later that evening it failed to respond to hot water demand (although it must have been working earlier as the radiators were still warm!)
Yesterday in the daylight I thought it worth doing a few basic checks.
The pin that operates the micro switch for DHW on the LHS seems to be working fine - moves in/out when HW tap opened.
I have tested both microswitches (DHW and the other flow one) and they seem fine (under 1 ohm) and operate fine.
The two thermistors both read around 11k ohm (seem fine)
I then isolated the water and drained the hot taps. I stripped the diaphragm from the top and then took the larger one out from the RHS - they were both okay (not split etc). I then removed the diverter valve from the RHS which was very dirty and sticking when moved. I had a brand new one (was left with the service manuals from 5+ years back) and a new brass bush/plug so I fitted these instead.
I also had another valve/pin thing for the LHS one (the one that operated the HW microswitch) but as this seemed to be working okay and I didn't have a suitable spanner to remove the nut I had to leave it.
Put it all back together, bled the hot water taps and pressurised it all back up to 1 bar or so and it all seemed to be working fine, hot water on/off fine and the heating working spot on. Used it several times since yesterday afternoon without trouble.
Got up this morning and went to have a shower...cold water! Arghh, heating had been on this morning so confused now.
Looked at the boiler and it's doing the same as before. Tries to start up on demand for HW or CH but it shuts down after 1-2 seconds. Interestingly the red fault light was slowly flashing for the first time. Powered it off and back on again and it started up so I could shower.
Stuck at work now and not sure what's best. I'd really like to be able to fix it myself but if it's not in the water block then obviously I'll leave it to a pro.
Any advice or pearls of wisdom? Is this a common fault?
The only concern I have was the valve I replaced was quite dirty (black and sticking) so does that indicate a grotty state of my CH circuit?
Many thanks and any help much appreciated. Sorry for the lot post but wanted to give as much info as possible!
Will
Will
