When i turn on the hot water the boiler ignites and the water gets hot as you would expect ,but as it reaches temperature the boiler switches off and then reignites .this is continuous until tap is turned off.I have done the following:
swapped over c/h and h/w thermistors and even took the h/w one out and plugged the hole .but still the same.
Stripped and cleaned primary and secendary exchagers and diverter.Replaced seals etc.
Checked switches on divertervalve and nither drop out even when bioler stops.
Checked fan vaccum switch although usually goes into fault if this fails.
Could this be a board fault or have i missed something?Please help! i dont want to spend £250 on a board unless i have to and my local plumbers dont have a clue!
