HELP!
My daughter has moved in to a property that i used to rent out after just having a baby, it has a halstead quattro combi boiler that has preety much been rebuilt over the last couple of years - totalling over £1K
I still have a problem in that it seems to work ok then the bugger will turn itself off overnigh or just when you need it, also it seems to stuggle to provide enough hot water for a shower, but the taps run hot, i have set the stats at about 60% to try and stop the constant cutting out - normally it can be reset by just pressing the reset button on the front and i have only twice had to press the small reset on the thermister (i think thats what it is) un the second pipe in from the front of boiler - behind the heatshield. any help would be great. Thanks
