Had my Quattro Gold for just over ten years now and I fear the latest problem may be the last.
As soon as the boiler tries to fire-up the fuse blows on the main board. I replaced the fuse and removed the cover and I can now see a flash from the gas controller at fire-up.
I've also noticed a pool of water beneath the boiler - on further investigation it looks like water is dripping from the heat exchanger into the burner, onto the gas controller and onto the boards.
I'm assuming it's a problem with the exchanger (there's some nasty corrosion in the burner!) but I'm wondering if it's worth trying to get it repaired or to just bite the bullet and get a new boiler
I've had several problems over the years and I know there's a ton of cr*p in the system so I know a flush and a new boiler is the best option. But I'm only going to be living here for another year tops and I'd much rather only pay to get it repaired!
Any thoughts?
Any thoughts?
