Hand held shower hose
7 Mar 2005
I'm sorry if this has been answered elsewhere but I can't find it.
I've just moved into a one year property and the main shower has a rain head with one of those fancy blue button on/off/boost plus a rotary temperature dial.
My issue is that they only fitted the rain shower head. For many reasons, having a hand held hose is desirable - not only for the obvious lower region cleaning - but also to aid cleaning the shower glass etc.
The shower is fully tiled so I doubt that it's worth trying to delve into the wall. So is there a way to add a hand shower head to an existing rain shower ?
Thanks for any advice.
Depends on what pipework is exposed, if any. If there is then you would need to get a diverter valve cut into the pipework feeding the rainshower head, then a hose and shower head could be attached to that. Trick is then getting one that will retrofit to your pipework.
