I’ve a 4M sliding door with a universal steel beam above it and I’m trying to hang curtains by drilling into the underside of the steel and affixing the mountings. I’ve bought HSS drip bits (dewalt) and self drilling (not self tapping) screws (4.2mm x 50mm). Nothing seems to work. This is a list of issues. I’ve so far drilled 3 holes with no success
1) self drilling screw wouldn’t go far enough in
2) I then created a pilot hole (3mm) upon which the head of the screw snapped offtwice leaving the shaft of the screw in the hole
3) drill bit then snapped
I’m using a drill to drill the pilot then using an impact driver to screw the screw. I tried a normal drill but the screw got stuck half way up…
Any help on which screw length / drill bits or links to the specific items would be really helpful
