Hang perforated steel sheet to wall
22 Feb 2009
London
I have a 800mm x 1700mm x 1mm thick perforated steel sheet which I want to screw to a single brick wall. I will be using 5mm screws as the holes are that size. How many screws at what length do you reckon I will need to secure it ?
I am planning on 8 40mm (1 and 1/2") screws either side. Do you reckon that will be able to hold the weight ?
