I have a 55cm basin that I wanted to fit in the bathroom. It’s become the job from hell!
Initially, I used the basin fittings and screwed into the wall to realise that they were hardly gripping. I then removed a tile and cut the plasterboard to see that there was a void of 2” behind the plasterboard. I then cut the section where the basin will fit and tried fitting a 4x2 batten - to which I intended to fit the basin. When screwing the basin to the wall, it was hit and miss as a couple of the screws gripped well and others succumbed to the brittle blocks into which I was screwing.
End result, the basin is starting to pull the batten away from the wall.
I did consider putting a pedestal under this basin (to take some of the weight) but the waste goes through the wall, outside the house and then into the manhole. It’s a Victorian house. A basin would mean that the waste pipe (exiting the external wall) is higher than where the basin ends up. Hence, I decided to hang the basin to the wall without the pedestal.
I am at a loss on how to solve this and would really appreciate your thoughts on this.
