We have lightweight thermalite blocks faced with dot and dabbed plasterboard. I have to hang a boiler on there. I'm scared stiff the thing is going to come off the wall as the blocks are so fragile (made like that, they aren't damaged).
What fixings do the pros use? I'm prepared to go to whatever lengths to make it work.
The only type of fixing which has given me any vague sense of confidence so far is epoxyed threaded rods set deep into the block. I would also cut out a section of 2"x2" plasterboard around each mounting rod and fill it with plasterboard adhesive to stabilise the rod from the face of the block to the face of the plasterboard.
The only type of standard plug fixing I've seen which gives me any confidence is the Fischer Twist Lock Anchor GB.
Thanks,
Robert
Thanks,
Robert
