Hanging a new interior door
14 Jul 2008
Manchester
Hi all,
I have a bit of a dilema with a new interior door I've just bought.
All the interior doors in my house are the 4 panel hollow type. Now, the one I bought is a solid item and weighs 3 times as much.
I have a router etc and have decided that the original 3 hole hinges are not strong enough, maybe they are - I don't know.
I have ordered some heavy duty 4" hinges which have 4 holes. I have never hung a door before but have watched a few videos on Youtube, but am still not confident taking the job on.
If the original hinges are strong enough it should be relatively easy to fit the new door.
However, if I have to use the larger hinges I'm not sure what to do regarding cutouts in the door jam.
Please advise.
You need to cut matching recesses in both door and casing leg. It may be as well to fill the original holes in the casing using the match and glue technique before routing out the new recess (over the position of the old one). Convention dictates that the top hinge on a door is set about 6in/150mm down from the top and the bottom one 9in/225mm up from the bottom.
Given you already have hinges I assume you're replacing an old door which is damaged or otherwise just old and scruffy?
Assuming the old door is going in a skip, why don't you use this as a practice? Use the door lock side to rebate your hinges, etc. and make sure you're comfortable before you start on the new one?
I've replaced all the doors in my last two properties, along with new doorframes in the last one. It's not "difficult" but you do need to be very patient when you're starting out. Don't be surprised if it takes you half a day or even a full day to fit a single door if this is your first time :)
