Hanging a punchbag on house wall
27 Mar 2012
Middlesex
I know there is plenty of info about hanging punchbags online, but I would like to hang one on a wall in my garage which is under (i.e. part of) my house. I assume the the wall is load bearing and as such want to be sure that I am not going to do any damage by hanging a punchbag.
The bag weighs approx 35kg (75lb).
I have the following bracket:
https://www.amazon.co.uk/RDX-Boxing...0858975&sr=8-2&keywords=rdx+punch+bag+bracket
However, I don't have the fittings, is something like the following what I need? (if not, please recommend an alternative, are these ones long enough?):
https://www.toolstation.com/shop/Sc...chors/sd2792/Fischer+Sleeve+Anchor+FSA/p65962
I assume that I want to drill into the actual brick rather than the mortar?
Because the garage is under the house, the damp course runs along the wall, about 3/4 of the way up. I am reasonably certain that all the fittings will be above this, but if I decide it could do with being lower, is it ok to go in underneath this?
Thanks for any info you are able to share.
The advert says it includes the wall fixings. Yes, drill into the bricks. You want to keep the fixings above the DPC, as you're not sure if there's tanking lower down, and you don;t want to break through that.
Thanks for the advice. I have been given the bracket and don't have the fittings. Do you think the ones linked to are what I'm after?
Thanks again.
I'd say they are over the top for a 35kg bag, but they'll do. You only really need a no 10 wall plug and a 60mm no 10 screw for that sort of weight.
Ensure they fit thru the bracket .
Are you just punching or kicking? In which case you may need to protect ceiling.
