Hanging external door between bricked entrance
8 Aug 2017
I need to fit an external door to an outbuilding. The outbuilding is brick and the gap between the side brick walls vary between 750 mm (top) and 730 mm (bottom).
I am hoping to fit a ledger and braced door weighing approx 15 kg. 2 widths of door are available, 686 mm or 610 mm.
I am hoping to get the 686 mm door and build a wooden frame using 20.5 mm thick batons, 34 mm wide. The batons will be drilled to the brick walls using frame fixings.
So 2 batons (41 mm) + the door (686) = 727 mm which just fits the overall minimum gap of 730 mm.
My concern is, are my batons going to be strong/thick enough to hang the door from? I am planning to use 3 x 350 T hinges.
Many thanks for any advice.
Have you posted the size correctly...
20.5 x 34
That's too small for a door liner.
You might get away with 20.5 if the hinges can go on the face not the edge, as I bet the hinges will be wider than 20mm.
Thanks for your reply.
Yes, I have posted the correct size.
I have just checked the T hinge size and see that the part that attaches to edge of the post is 30 mm so can see now that the frame I am intending is at least 10 mm to narrow if I use T hinges on the edge.
I guess my only options are to use standard door hinges on the face of the frame or get the narrower door 610 mm instead of 686 mm.
If I stick to the wider door and attach standard hinges to the face of the frame, would the frame size (20.5 mm x 34 mm) by strong enough?
Thanks.
