As above and.....
Check all the batch numbers before you start
Measure up and make sure youl have enough paper......DONT open the rolls until your confedent that you have enough......it may be the last of a batch or end of line.
Set the wall out first.....dont start in a place that will leave you putting a half inch strip in at the end of a wall
Always keep the labels..even if the batches are the same...shading problems cans till occur......if you throw the labels youl have no comeback
Check to see what the pattern type is...ie a drop or offset match..or a straight match
Try to restrict the wastage in corners...allow the bare minimum...3mm...if you cut too much off you will lose the pattern.
If its a drop match then you can measure the first length, put it on the paste table and cut it, then match the second length to it and cut that, take the second lenth away for a while and cut 4/5 pieces the same as the first length.......then bring the second length bcak and cut 4/5 pieces the same as that......then take one length from the first pile and put it on the table...then one from the second.....repeat this until you have ten 8/10 pieces on the table
pieces 1,3,5,7,9 should all be the same and pieces 2,4,6,8,10 should all be the same.
If its a straight match then all pieces will be the same.
--> l
l <-- drop match
-->l<-- straight match
You said the paper has a big pattern....so my guess is that its a drop pattern
You can try using paper from a couple of rools....they say that helps reduce wastage....personally I dont think it makes any difference
As CC said...make sure you dont end up with half a flower running through the ceiling line.....try to find a section of the paper without a pattern..if your ceiling line is uneven this will help hide it.
The same goes if you have a dado rail.....dont chop half a pattern off......find a blankish area of the paper....if possible.
If you have a chimney breat cut a few strips of paper and tape them together...then jiggle them around to ensure the pattern is equally spaced on both external corners of the breast wall.
Dont rely on starting in the centre....this doesnt always work.
Above all....read the instructions.......thats what they are there for
Not being funny, but there are sooooooooo many aspects to papering its difficult to cover them all on here.....and rqually difficult to express it (especially when you have just had a couple of stella's)
If you hit on a specific problem....write in again
