Is there a particular setting tool size I'd need for this?Have a look at 'hollow wall fixings '......all you need and a 7mm drill hole does the job.
I'd recommend the setting tool too but it's not strictly necessary.
John
Brilliant, do I need any particular size of the anchor screws?
I'll have a look next time I'm in. Thanks.lidl are selling both pack of anchor screws and tool - I purchased the box of anchor screws as i may only need occasionally and so did not bother with the setting tool and screws box
I purchased the other day , so may have sold out now
Re stud detectors, I think just using a small round magnet would probably suffice.I think the setting tools can handle most hollow fixings as the thread is generally 5mm. So long as the setting tool can grip the screw head it will be able to collapse the fitting.
Can't advise on a wire detector I'm afraid, but I wouldn't totally rely on them anyway.....stud detectors are worse!
John
The setting tool is only for use with hollow wall fixings.
John
