Hansgrohe mixer shower bar not hot enough
H
HiZ
Hi, my Hansgrohe Marin Centostat is not hot enough even though the combi supplied water is very hot.
Has always been ok for me since install although girlfriend decided shed like it hotter!
Temp set as per manual although on full adjustment it's still not hot enough.
Thermoelement removed and cleaned.
Water pressure unknown although on low flow rate the temp is the same.
It's as if the mixer can't swing far enough to add more hot and less cold.
Amy ideas of testing of modifications such as restricting the cold before I stump up £70 on a thermoelement which might not solve it!
Thanks very much for any advice.
Take out the thermostatic cartridge and soak it in de-scaler for 24hrs, if that doesn't work then new cartridge is needed.
Andy
