Hansgrohe shower head/recommend?
18 Mar 2008
Belfast
Looking to replace an old shower head and considering a better quality/better needs met product.
Came across Hansgrohe products and appear to be well reviewed not only here, but in Europe/USA. Have a standard Mira mixer shower with the usual type of variable spray head. It's not a fixed head, but the rail mounted type. Looking for a larger head type in general to widen the water flow.
Water pressure is not an issue. Gravity system, but both showers are connected to a Salamander pump which does a great job. In fact the pressure can be a little much on some head settings so hoping by spreading it out over a wider head will reduce it a little. I just seem to find the standard type Mira/Triton/other brand round type heads. Looking as stated above for something a little bigger, but fits on the standard riser rail fittings.
Any experience of Hansgrohe or any other reommendations would be much appreciated
