I have installed a gate on my property,with the gate swinging in.Problem is that the ground is on a incline and the bottom of the gate rubs on the ground .Is there a hinge that would raise the gate as it opens?
Rising butt hinges only lift the door about 3/4" so that sounds like it wouldn't be enough.
How about creating a flat area where the door swings, and forming a step up onto the next level?
John
