Has anyone got a top tip
15 Feb 2008
Manchester
For removing old B.S.1010 w.h.basin taps, with the square lugs, and fitted into square holes with putty???
I have tried all the usual tools, but can't budge the back nuts.
Other than cutting and grinding the top of the tap off, What options do I have?
And please don't suggest, tap restorer kits. I am looking to remove the taps,
Thank in advance
18 inch stilsons on tap and 18 inch spanner on bottom of box spanner
New basin?
When the tap tail is in a ressece about 3 to 4 inch deep it a bit difficult to just apply heat to the back nut only.
I cut a hole in an asbestos mat and fitted it over the tap against the ceramic of the basin - then heated the tap from above :idea: I still have the mat with the hole in it
Does that work? I would have thought the tail would expand more than the back nut! as more heat to tail.
How did you get the mat over the spout.
I Have in the past removed the bonnet of the tap and applied heat direct into the tap to no avail,
ie The whb split
buck - use a hot-air paint stripper to heat the offenders up (this'll not only 'soften' the "putty" {which might be decades old plumbers mate} but also introduce a bit of expansion to break the tap/nut jam) then apply a box-spanner to the back nuts AND a Stiltson to the tap body. IMO a box spanner is less likely to slip than a basin wrench, plus extra welly can be applies via an extended tommy-bar.
I read on a forum thread somewhere that these Bearhug wrenches are good, not tried one myself though. Too much heat & you may smash the basin.
Cut the slot in the backnut with a Dremel, if you can get it in? Then use a hammer & slotted screwdriver to open up the backnut.
Got a set of jaw-droppers, they have been pretty handy.
OP have you tried using a penetrating spray (rocol) or crack-it release spray on the backnuts? Maybe worth a try.
Hit the spout lightly back and forth with a hammer a few times , this will loosen the red lead/plaster or putty that was used to set them in..............................if the basin breaks then buy a new one.
