I’d like some advice on what to do regarding my boiler, which was installed by British Gas around 14 months ago.
I’ve had multiple breakdowns and callouts since then, and have recently been told by an independent plumber that the installation was done incorrectly.
He said the system wasn’t powerflushed before the new boiler was commissioned, and also that the pump isn’t working correctly and should have been replaced as part of the installation job. The pump is apparently causing a circulation problem, with water going into the loft tank (it sounds like there’s a train in the loft when the heating comes on).
A BG engineer came around and confirmed that the powerflush hadn’t been done, and also said other installation problems needed to be rectified.
I eventually received a call from the guy in charge of my area, who said he’d send someone round to do the powerflush.
I’m concerned though that my boiler warranty is now invalid, and also that the lack of a powerflush may have caused damage to the boiler. I was told it wasn’t a problem as I’m covered by Homecare - and that the Powerflush would sort things – not much use to me though if I decide not to go with Homecare in the future.
Should I accept the powerflush and let it be, or is it likely that my boiler has been damaged? I’m on the phone to BG again right now as the boiler has an F1 error and resetting it doesn’t work.
