Quick question, as I can't really find the answer on Google or this forum.
My Glow Worm Flexicom 18sx comes up with the F9 pressure sensor fault when firing up unless the pressure when cool is 2.0 bar. It used to be fine starting up from 1.6 bar, but the fault kept coming back and increasing the pressure 'fixed it' each time. Now when hot it gets above 2.5 bar, so I took some water out and dropped the pressure to 1.9 bar when cold. Same problem. I've had to top it up to 2.0 bar and now it's working.
So I'm guessing a pressure sensor fault? It also sometimes sounds like there air noises in the boiler when trying to start - is that something that can happen?
