I just had a new boiler installed and have a concern over the system flush that has been performed.
I had two radiators that were taken off the wall for damp treatment months ago. A few days ago, in preparation for the boiler installation, my husband has installed the wall brackets and we have put those back on the wall and connected by screwing on the nut that connects the radiator to the pipes. He has not touched any valves etc. I have told the boiler installer about this and requested that he checks that the radiators are connected properly. He has done the cold and hot flush according to the Installation certificate.
It was only towards the end of the whole installation when the heating was on, that I have noticed that the 2 radiators were still cold so I have pointed that out to the installer who then discovered that the lock shield valves were completely shut on them. It appears that they were closed when removed for plastering to avoid draining the whole system,as the people who took them off were plasterers not heating engineers and they did it the quick way. Also one radiator upstairs was set to 0 at the thermostatic valve. Does it matter at all what setting are the radiators set to when doing the flushing? Would the water reach the rads to flush out the sludge with lock shield or thermostatic valves closed? The installer has assured me that it doesn't matter and after he opened up the lock shield valves, a while later, the radiators became hot. I would like a second opinion please. Even though everything works fine,apart from the rads needing balancing, I have heard that the system flushing is very important for the health of the heating system and would like some reassurance. I am worried that the rads did not get the clean they should and the installer only said that it will be fine because he couldn't be bothered to do another system flush. He has also snapped one of the lock shield valve tops that enable turning it and insisted that it is not up to him to fix it as there was no reason for the valves to be closed in the first place.it was first thing I asked to check before they started!he managed to turn the valve enough to get the rad going but it obviously could be a problem in the future.
