Have a Worcester 240 combi, Automatic air vent failed again and we lost hotwater but heating is ok. Water comes out of the chamber over the electronics and screws the driver board, what a crap design. So replaced board again as well. The whole start up sequence works fine.
Still have a problem
When have hw tap is operated the on demand light does not go on and the start up sequence does not happen, but get hw in the heat exchanger but not out to the tap. If I take the microswitch off the Diverter valve the and press both buttons the hw sequence starts but still no hot water.
Qn
When the hw tap is opened does the diverter valve operate, let the water flow through the heat exchanger, operate the switch, start the heat sequence. Dont really want to change the diverter valve unless I have to.
Any help appreciated.
Qn
