Hi all, I have to fit a new pop up in the bathroom basin ( its the one you push down to engage & push again to release) it is fitted in a vanity unit so access is restricted. Is there a box spanner available to remove / replace the nut underneath? if so could someone point me to a link so I could buy a cheap one. I have an adjustable spanner & also a pair of pump pliers but there is not enough space to use them. Also I am using a Dudley basin waste seal kit (Screwfix code 8795R) should the soft washer fit inside the sink between the basin & pop up assembly? Any help on these 2 questions would be much apricated.
Thank you for your time.
Brian.
Brian.
